richlife69
Nov 04, 2015Star
Will WNDR4300 block remote connection between PCs on same subnet?
My home network appears to be working just fine except that I'm having problems establishing remote connections between PCs. I've introduced Glasswire (a graphical network monitor) which is not able...
- Nov 05, 2015
I'm pretty sure I have the answer to this problem. I learned that Windows 10 does not support telnet. You can install the telnet client, but there is no longer the option to install telnet server. All my PCs are Win10, so that's why I can never establish a telnet connection.
richlife69
Nov 04, 2015Star
Yes, it is enabled. I can telnet outside of my network and each computer can establish a telnet session with itself, so that's why I'm looking at the router though, frankly, I have no real reason to suspect it. But then, I have no idea why telnet isn't working within the subnet, so grasping for straws.
ElaineM
Nov 05, 2015NETGEAR Employee Retired
Which one you're trying to telnet to?
- richlife69Nov 05, 2015Star
