shinsangeun's avatar
shinsangeun
Wired Backhaul is not working since some points(RBR20+2 of RBS20)
I have used RBR20 and 2 of RBS20 and I set up wired backhaul and had no issue at all.
However, since about 2-3 weeks ago, internetet was not working and I noticed that one of satellite's color became purple in orbi app-when I checked it in 192.168.1.1 admin windows, its status was good, but internet was not working.
Since that day, I unwired backhaul for both satellite, and now everything is fine.
BUT I want wired backhaul for stronger network, but it suddenly stop working.
I tried switching cable and switches, but nothing solved yet.
What do you think the problem I have?
Attached is the screenshot when I wired backhaul to one of my satellite.
  • plemans's avatar
    What switch do you have it connected to?
    If you direct wire the satellite to the router, does it work?
    What modem/gateway do you have?
    What firmware is on the router? And the satellites?
    • shinsangeun's avatar
      shinsangeun
      I am using D-Link unmanaged switch.
      I didn't test direct wire the satellite to the router.
      I am using Motorola cable modem provided by Spectrum.
      Firmware version is 2.5.1.16 which is the lastest one as of now.
      Again, it had been working without any issue, but suddenly happened.
