freebie
Jul 17, 2017Aspirant
Wireless Bridge to WiFi
I've set up my router as a wireless bridge to another. This allows me to use the connection of the parent router via the ethernet of the one in bridged mode. Is there a way to turn on the other WiFi radios to instead be able to communicate via the bridge to the parent router over WiFi?
The gentleman here: https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/R6400-as-Wireless-Repeater-to-a-Distant-Access-Point/m-p/1139268 was looking for the same thing but he was directed to bridge mode which is only the first half of the problem.
Thanks
- netwrksMaster
Sounds like you may be descrbing AP mode? base router<<--ethernet>>>R6400. Is this what you are describing?
- freebieAspirant
Thanks for the quick response.
Unfortunatly I'm not able to get a wired connection to the orgin. I was looking for a way to go base <- wifi -> r6400 <- wifi -> devices.
- freebieAspirant
DD-WRT seems to have this feature (named Repeater Bridge): https://www.dd-wrt.com/wiki/index.php/Repeater_Bridge
