Kmmmn's avatar
Kmmmn
WN3000RP v3 N300 extender IPV6 disabling
Hi.  Wondering if it’s possible to disable IPv6 on my N300 extender and if so, how.
thanks,
KM
  • michaelkenward's avatar
    michaelkenward
    Why do you want to do this? You are trying to fix something that doesn't work?
    I see no mention of IPv6 for the WN3000RP range.
  • plemans's avatar
    Was wondering the same in why are you trying to achieve this?
    It should be set by your router, not a wireless extender.
    • Kmmmn's avatar
      Kmmmn
      i have a firestick and cannot disable ipv6 on it.  I have ipv6 disabled on my router but it still shows on my FS.  I wondered if I used my Netgear as an access point I could connect my FS to it, but only if I could set it up with ipv6 disabled.  Thanks.
        michaelkenward
        Same question as plemans really, why do you want to do that?
        IPv6 is a newfangled thing that appeared after the WN3000RP from 2011.
        Then there is the fact that the WN3000RP is a range extender. In that case, the router it extends is in charge of network management.
  • My Apple Airport Extreme 802.11ac router handled IPv6 perfectly, but the connections (regardless of IP addressing) were flaky and I got tired of hearing all the people in the house complaining about "the internet". So, I decided to get a new router. I did research to try to find the stablest, fastest router I could. I decided on a Netgear R7800.
    I am very happy with the speed and connectivity of the Netgear, but it fails with IPv6 because the firmware blocks ICMP, or some such. My research had not revealed this issue, but after I experienced it, it was easy to find many complaints about it all over everywhere. It's not just my particular model, it seems to be all Netgear.
    In Netgear's own user forums, the "accepted solution" is to buy another brand. The Netgear engineers apparently refuse to fix it, citing security concerns.
    Is anyone here aware of a fix or workaround for this?
