putter63
Jan 28, 2022Guide
WNDR 3400v2 Genie Utility software availability since it has been taken out of use?
I live in a rental house and the router is upstairs in someones else's apartment. My home PC crashed and I had to reinstall everything. I tried to reinstall the Genie utility but its no longer supported. Does anyone know if there is a way to find and reinstall this app/program?
If that took care of it, you can mark it solved so others aren't trying to "fix it" as well. :)
Do you need it?
You can manage the router through its ip address
You can download it here under the OS of your operating system:
genie | Product | Support | NETGEAR
- putter63GuideI used to know how to find the IP Address for my stuff but I can't remember. Can you walk me through please?
How do I access the router settings using the IP Address?
Thanks in advance!- plemansGuru - Experienced User
you can try and type routerlogin . net
or if you pull up a command prompt on your computer, you can type ipconfig
If you're not in a double nat, the default gateway will be the routers address.
How to Find Your Router’s IP Address on Any Computer, Smartphone, or Tablet (howtogeek.com)
