mccollamj1
Jan 13, 2017Aspirant
WNDR3400v3 slow wired connection
I recently upgraded my internet speed from 50mbps to 100mbps. Prior to the upgrade my wired connection speed to the router was always very near that 50mbps mark and my wirless speed was also very clo...
- Jan 21, 2017After trying that I've accepted it is hardware failure. Purchased a new router. Thank you.
mccollamj1
***Edit*** All cables worked at 120+ mbps directly connected to the modem. (not router... that is the problem).
ElaineM
Jan 16, 2017NETGEAR Employee Retired
Welcome to the community, @mccollmj1
Do you have the latest firmware installed in the router?
How about doing a factory reset? If you have not, try to factory reset the router then reconfigure it afterwards then observe your connection.
