sktn77a's avatar
sktn77a
Virtuoso
May 16, 2017
WNDR3700 as wireless access point?
I have a Netgear WNDR3700.  As there is no v1, v2, v3 after the model, I am assuming it is a v1 - am I correct in that assumption?  It has firmware version 1.0.7.98NA (looks like the original or earl...
  • sktn77a's avatar
    sktn77a
    May 16, 2017
    Well, got everything up and running but the router has a problem on the 2.4GHz band - weak, almost non-existen broadcast power.  I was going to keep it and just use the 5GHz band but then decided to toss it and get one that works.  Yea, Craigslist (not)!
