sktn77a
May 16, 2017Virtuoso
WNDR3700 as wireless access point?
I have a Netgear WNDR3700. As there is no v1, v2, v3 after the model, I am assuming it is a v1 - am I correct in that assumption? It has firmware version 1.0.7.98NA (looks like the original or earl...
- May 16, 2017
Well, got everything up and running but the router has a problem on the 2.4GHz band - weak, almost non-existen broadcast power. I was going to keep it and just use the 5GHz band but then decided to toss it and get one that works. Yea, Craigslist (not)!
sktn77a
May 19, 2017Virtuoso
Under router status - the wndr3700.
- WickedDumMay 20, 2017Aspirant
Thanks.
I de-selected DHCP on the configuration page for the WNDR3700. It does not say "DHCP Client".
I've been trying to think how I could explain this better. I'm thinking that I can provide screenshots of the different configuration screens to ensure I am doing it correctly. And it would be a good record for anyone else that tries this same in-home wifi configuration. I'll try to complete it this weekend.
My main problem remains: When I enter the reserved IP address - 10.100.10.125 in this case - I still canNOT get back into the WNDR3700 without pushing the factory reset button... Any more thoughts?
- sktn77aMay 20, 2017Virtuoso
Well, your laptop isn't getting an IP address from the WNDR3700 when its hard-wired to it.
Did you try "routerlogin.net"?
Do you have the latest firmware?
Have you tried leaving DHCP on (wndr3700)?
- WickedDumMay 21, 2017Aspirant
Thank you for your help!
I haven't had to a chance to get pictures yet...
"your laptop isn't getting an IP" But...I can access the router after I reset it...
Did you try "routerlogin.net"? Yes
Do you have the latest firmware? Yes
Have you tried leaving DHCP on (wndr3700)? No. I set a reserved IP on it. I added the gateway, but no DNS. I figured all was well. Guess it isn't, cuz I'm asking for help...
I have progressed a bit...
After I modified the wireless adapter, putting in the reserved IP. I turned on wifi on my laptop and it connected. I would like to know if I erred somewhere. I believe these are the important screens:
If you don't see any errors, I'll move it to the front of the house and try to connect a couple of different ways.
I do appreciate your help. I know it takes time...
