sktn77a
May 16, 2017Virtuoso
WNDR3700 as wireless access point?
I have a Netgear WNDR3700. As there is no v1, v2, v3 after the model, I am assuming it is a v1 - am I correct in that assumption? It has firmware version 1.0.7.98NA (looks like the original or earl...
- May 16, 2017
Well, got everything up and running but the router has a problem on the 2.4GHz band - weak, almost non-existen broadcast power. I was going to keep it and just use the 5GHz band but then decided to toss it and get one that works. Yea, Craigslist (not)!
sktn77a
May 20, 2017Virtuoso
Well, your laptop isn't getting an IP address from the WNDR3700 when its hard-wired to it.
Did you try "routerlogin.net"?
Do you have the latest firmware?
Have you tried leaving DHCP on (wndr3700)?
WickedDum
May 21, 2017Aspirant
Thank you for your help!
I haven't had to a chance to get pictures yet...
"your laptop isn't getting an IP" But...I can access the router after I reset it...
Did you try "routerlogin.net"? Yes
Do you have the latest firmware? Yes
Have you tried leaving DHCP on (wndr3700)? No. I set a reserved IP on it. I added the gateway, but no DNS. I figured all was well. Guess it isn't, cuz I'm asking for help...
I have progressed a bit...
After I modified the wireless adapter, putting in the reserved IP. I turned on wifi on my laptop and it connected. I would like to know if I erred somewhere. I believe these are the important screens:
If you don't see any errors, I'll move it to the front of the house and try to connect a couple of different ways.
I do appreciate your help. I know it takes time...
- WickedDumMay 27, 2017Aspirant
It's been in the front of the house for several days. No luck. The connection keeps dropping.
Any thoughts folks?
An additional question: How can you tell if your laptop, etc. received its connection from the AP?
