Lcarey596's avatar
Lcarey596
WNDR3700 Router Problems
The WNDR3700v1 router worked yesterday and today I can't even sign-on to it.
I turned everything off and rebooted the modem, rebooted the router, rebooted the computer. still no internet.
Then I noticed that the router was rebooting by its self, so I hard reset the router and it fixed the self-reboot and did the above all over again, didn't work.
Then I tried to sign-on to the router with the 192.168.1.1 and the computer kept telling me no, that it can't find it.
What is going on? Please help me!
  • > WNDR3700v1 router worked yesterday and today I can't even sign-on to
    > it.
       Perhaps it (or its power adapter) failed.
    > [...] didn't work. [...]
       Not a very detailed problem description.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the Setup Manual and/or User Manual.  Read.
    Look for the LED descriptions and "Troubleshoot".
       What's the IP address of your computer when you do that?
    > What is going on? [...]
       With my weak psychic powers, describing _that_ is _your_ job.
    • Lcarey596's avatar
      Lcarey596
      Wave Broadband came out to check everything and also looked at the modem, and it was Okay.
      They said it was my router that died!😒
      Thanks
      • wcalifas's avatar
        wcalifas
        Prodigy
        You can try another power adapter of the same voltage and see if it was that. If you say you couldn't log into it maybe it has died. You can log into it by connecting your laptop to one of the 4 LAN ports on the back, on your browser either type 192.168.1.1 or http://routerlogin.net. The user is admin and the password is password. Let us know what happens so we can further help you.
