Gamerear19
Mar 18, 2016Aspirant
WNDR3700v2 Router Vulnerability
So i got a WNDR3700v2 with latest firmware at the moment and I noticed theres a vulnerability in it but no more updates are being made for it. Is it possible to avoid the vulnerability if I use a very strong wifi password and router settings password along with disabling remote management, readyshare, dlna, upnp, and other things and make the router be just a simple router with a firewall and no fancy features. Why I ask is the router been working great after 5 years which is much longer than the average router now days. If not does the netgear wndr4300v2 have any known vulnerabilitys that hasnt been fixed.
It's best to keep your router updated to ensure security.
Here are the latest Release Notes for WNDR3700v2 and WNDR4300v2 for your reference.
The release notes states all the fixes and known issues using the latest firmware.
1 Reply
- ElaineMNETGEAR Employee Retired
