VinceMa
Feb 08, 2017Aspirant
WNDR3700v4 constantly changing reserved addresses
I am trying to set up a home surveillance system. The system has 4 cameras and a NVR. I spent all day setting up the system, I powered it down for the night. The next day, I found that some of the ca...
- Feb 09, 2017
VinceMa wrote:
michaelkenward wrote:Sigh.
Please learn how to use the "Quote" button at the top of the messages that you reply to.
It is on the right-hand end of the row of labels for:
Rich Text HTML Preview -------------------------------------------------------------------------------------------------------------------Quote
Otherwise it is impossible to work out where the original message ends and your answer begins.
I'm new at posting anything on a message board or any other site (other than Facebook) for that matter, so pardon my ignorance. I will do better in the future. Thanks for the advice.
Vince, that wasn't intended for you but for the person who replied to your message.
The challenge you have is to work out how the cameras and the NVR handle IP addresses.
Do they come with a fixed IP address? Or is there somewhere in their own control panels (if they have one) that let you set them to use a particular IP address?
If the cameras do wifi and LAN, then there should be some way to control their behaviour.
If you can tell each device to always use a particular IP address, then you should be able to tell your WNDR3700v4 to keep its hands off those addresses. The control interface in the WNDR3700v4 should have an "Address Reservation" panel for that.
Another approach would be to go to the Address Reservation page, probably in
- Advanced
- LAN Setup
- Address Reservation
- Add
See if you can tie each camera's MAC Address to a fixed IP Address.
If you look at the manual for your WNDR3700v4
WNDR3700v4 | Product | Support | NETGEAR
you can start at page 42.
If you tell people what the camera kit is, maybe someone here has grappled with them before and can pass on some tips.
Good luck, you may need it.
William10a
Feb 08, 2017Master
[I am trying to set up a home surveillance system. The system has 4 cameras and a NVR. I spent all day setting up the system, I powered it down for the night. The next day, I found that some of the camera didn’t work. When I checked, their addresses had changed. Not only had they changed, they went from wireless to wired. At this point I started taking screen prints to keep track of the address changes. After some on line searching, I found that I needed to make the cameras and NVR’s address reserved. After doing this, applying and rebooting, I once again took a screen print of the address. It is still changing the address of my devices. If I shut the camera equipment down and power it back up again, some of the address change. Sometimes they are wireless and sometimes they are wired. Can anyone help?]
Can you assign each camera and nvr to a static ip address in there setup on the wndr3700v4 change the dynamic address range and set the it to not incinding the static ip range that you are using for the camera's and nvr's . That's why a server has a static ip address it woulld change it's ip address if the router were allow to assign the address every the power went out. Most wireless printers are a static address so the computer can find the printer on the network.
- VinceMaFeb 08, 2017Aspirant
I will give that a try and see if things change.
- michaelkenwardFeb 09, 2017Guru - Experienced User
Sigh.
- VinceMaFeb 09, 2017Aspirant
So how about a little help with this problem? I do not keep my surveillance system on 24/7. So when I turn it on I need the equipment to have the same IP address. After some internet research I found that I should set the cameras and NVR in the Address Reservation table because that is what it is used for, to assign the same IP address to the same MAC address (devise). So that is what I did. So why is it that when I turn off the equipment (surveillance system) and then later, back on again, one or more of the cameras have a different IP address? And to add to that, some of the cameras show up as wired even though they were set up as wireless and are not connected to the system via a cable. Sometimes I will get entries into the Attached Devices with Device Name <Unknown> with an IP address and the same MAC address shows up in the Wireless Devises table with the same info (or visa versa)! This is really weird. The previous “helper” suggested that I set up or change a dynamic address range. Although I am quite technical, my expertise in Networking is sorely lacking and extremely limited. I tried to follow his suggestion in the User’s Manual but could not. I down loaded the latest WNDR3700v4 User’s Manual dated December 2012 replacing the old one I had dated November 2012. Some of the instructions, pictures and/or descriptions in both the manuals differ from what I see on the screen in front of me. Not wanting to screw things up and have a piece of equipment that I would have to do a factory reset on, (even though I have saved config files) sitting next to me and having to start all over again is not appealing to me. I decided not to make any changes that I was not familiar with or comfortable doing. Of course, there could be a problem with the router but I doubt it.
So my problem still exists, and little help here would really be greatly appreciated.
- Advanced
- LAN Setup
- Add
