VinceMa's avatar
VinceMa
WNDR3700v4 constantly changing reserved addresses
I am trying to set up a home surveillance system. The system has 4 cameras and a NVR. I spent all day setting up the system, I powered it down for the night. The next day, I found that some of the ca...
  • michaelkenward's avatar
    michaelkenward
    Feb 09, 2017
    VinceMa wrote:
    michaelkenward wrote:
    Sigh.
    Please learn how to use the "Quote" button at the top of the messages that you reply to.
    It is on the right-hand end of the row of labels for:
    Rich Text HTML Preview -------------------------------------------------------------------------------------------------------------------Quote
    Otherwise it is impossible to work out where the original message ends and your answer begins.
    I'm new at posting anything on a message board or any other site (other than Facebook) for that matter, so pardon my ignorance. I will do better in the future. Thanks for the advice.
    Vince, that wasn't intended for you but for the person who replied to your message.
    The challenge you have is to work out how the cameras and the NVR handle IP addresses.
    Do they come with a fixed IP address? Or is there somewhere in their own control panels (if they have one) that let you set them to use a particular IP address?
    If the cameras do wifi and LAN, then there should be some way to control their behaviour.
    If you can tell each device to always use a particular IP address, then you should be able to tell your WNDR3700v4 to keep its hands off those addresses. The control interface in the WNDR3700v4 should have an "Address Reservation" panel for that.
    Another approach would be to go to the Address Reservation page, probably in
    • Advanced
    • LAN Setup
    • Address Reservation
    • Add
    See if you can tie each camera's MAC Address to a fixed IP Address.
    If you look at the manual for your WNDR3700v4
    WNDR3700v4 | Product | Support | NETGEAR
    you can start at page 42.
    If you tell people what the camera kit is, maybe someone here has grappled with them before and can pass on some tips.
    Good luck, you may need it.
