kcopter
Dec 02, 2016Aspirant
WNDR4300 not able to setup time machine
I have looked up at Netgear and see that the WNDR4300 is time machine happy but it does not show up in time machine list. Need to know how or do I need to buy an new router? I did try an older apple wireless and it worked just fine but it is not mine.
Any help would be nice, thank you for any help.
Hi, It did not work or even show up noe the network. Moving on no more wast of time with Netgear stuff.
Thanks for the help.
- kcopterAspirant
I have done it all but still will not show up for time machine. I can see other wise. I think it worked once when I first got it but now nothing. Still think Netgear put something out that it does not really do. Have all updates done to it.
But thanks for the help so far.
- ElaineMNETGEAR Employee Retired
Another thing you can do is to reinstall the firmware then do a factory reset after.
Once done, reconfigure the router settings to get back the Internet connection.
