sambrookjm
Apr 15, 2018Follower
WNDR4300 Router still blocking sites removed from List
I tried to set up a parental control to block YouTube on the NETGEAR router listed above. It is running the latest version of the Firmware (V1.0.2.98 as of this message) I attempted to block YouTub...
- Apr 18, 2018
Hi sambrookjm,
Welcome to the community!
1. Yes, doing a factory reset may clear the blocking of the site and all your previous configurations.
2. If the issue (YouTube not being blocked on the PC) persists, you may look into LPC (Live Parental Controls). This link may help out.
3. Once set up, you can login to https://netgear.opendns.com and go to Account Settings > Blacklist/Whitelist.
Dexter
Community Team
DexterJB
Apr 18, 2018NETGEAR Moderator
Hi sambrookjm,
Dexter
Community Team
- DexterJBApr 24, 2018NETGEAR Moderator
Hi sambrookjm,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
