dadcyber's avatar
dadcyber
WNDR4500 and Cisco Service blocked: ICMP_echo_req
In my home have i a WNDR4500 and to the wan outside a Cisco from te provider ziggo in the netherlands.
The Cisco is programming as 1 ip adres to the netgear but i have programming to 1 to 100 ip.
In the netgear its only the 1 ip on the wan so y can connected.
I have a lot of slow internet connections and the logbook give the next problems.
[Service blocked: ICMP_echo_req] from source 88.159.40.82, Sunday, Jun 26,2016 09:58:11
[Service blocked: ICMP_echo_req] from source 84.116.245.161, Sunday, Jun 26,2016 09:24:35
[Service blocked: ICMP_echo_req] from source 83.128.178.109, Sunday, Jun 26,2016 09:23:30
[Service blocked: ICMP_echo_req] from source 178.188.57.122, Sunday, Jun 26,2016 09:20:27
[Service blocked: ICMP_echo_req] from source 37.188.66.133, Sunday, Jun 26,2016 09:15:43
[Service blocked: ICMP_echo_req] from source 46.227.238.192, Sunday, Jun 26,2016 09:15:43
[Service blocked: ICMP_echo_req] from source 37.188.66.133, Sunday, Jun 26,2016 09:15:40
[Service blocked: ICMP_echo_req] from source 46.227.238.192, Sunday, Jun 26,2016 09:15:37
[Service blocked: ICMP_echo_req] from source 83.162.189.33, Sunday, Jun 26,2016 09:15:34
[Service blocked: ICMP_echo_req] from source 46.227.238.192, Sunday, Jun 26,2016 09:15:34
[Service blocked: ICMP_echo_req] from source 84.116.245.161, Sunday, Jun 26,2016 09:15:22
[Service blocked: ICMP_echo_req] from source 77.162.39.53, Sunday, Jun 26,2016 09:15:06
[Service blocked: ICMP_echo_req] from source 84.116.245.161, Sunday, Jun 26,2016 09:15:04
[Service blocked: ICMP_echo_req] from source 82.161.183.81, Sunday, Jun 26,2016 09:15:00
[Service blocked: ICMP_echo_req] from source 84.84.197.176, Sunday, Jun 26,2016 09:14:53
[Service blocked: ICMP_echo_req] from source 195.240.106.78, Sunday, Jun 26,2016 09:14:51
[Service blocked: ICMP_echo_req] from source 84.84.197.176, Sunday, Jun 26,2016 09:14:50
[Service blocked: ICMP_echo_req] from source 95.90.194.23, Sunday, Jun 26,2016 09:14:48
[Service blocked: ICMP_echo_req] from source 195.240.106.78, Sunday, Jun 26,2016 09:14:48
[Service blocked: ICMP_echo_req] from source 84.84.197.176, Sunday, Jun 26,2016 09:14:47
[Service blocked: ICMP_echo_req] from source 195.240.106.78, Sunday, Jun 26,2016 09:14:45
So i think that the cisco is ping the netgear?
Of it is a realy message the attack my istallation.
see my cisco
spi firewall protection  medium
Ip 6 firewall protection on
Block fragmented IP packets
Block Port Scan Detection
IP Flood Detection
Block Anonymous Internet Requests
  •  Thanks for your welcome.
    By the wan side the ping is of "Respond to Ping on Internet Port.
    By the Ziggo modem in the firewall choice the
    SPI Firewall Protection    was medium en now low.
    The problem is over.
    Thanks for your reply
    greetings Dadcyber
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hello dadcyber
    Welcome to the community!
    Is "Respond to Ping on Internet Port" unchecked? You should be able to see this option under the WAN setup in the admin page of the NETGEAR router.
    • dadcyber's avatar
      dadcyber
      greetings Dadcyber
      • ElaineM's avatar
        ElaineM
        You're welcome.
        Thank you for your update.
        Have a great day!
