nougain's avatar
nougain
WNDR4500 Stopped Working | Power Blinking Green, Internet Solid Amber
My WNDR4500 Stopped Working for past few weeks. Power LED is Blinking Green and Internet LED is Solid Amber. All other LEDs are dead (2.4 GHz Wifi, 5 GHz Wifi, USB1 and USB2). Ethernet LED glows though if I connect router LAN port to my laptop Ethernet port.
I researched the internet and tried few things but could not succeed. I am given to understand that my firmware is corrupt. Don't know how I can bring it back to functioning.
I tried this: http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the-setup-cd-recovery-tool
Perhaps, I don't know how to access the router now over the wired connection to install the firmware afresh.
Please help
Thanks.
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    Have you first of all just tried a factory reset of the router?
    In the instructions for firmware recovery did you set a static IP at the computer, and is the computer directly connected to the router? I suggest that when you do this you disconnect the router from the modem or any other network devices other than the computer.
    Is the router still within its warranty period?
  • Have you first of all just tried a factory reset of the router?
    YES
    COMPUTER IS DIRECTLY CONNECTED WITH THE ROUTER USING A LAN WIRE. I CAN SEE THE CORRESPONDING LED GLOWING. PERHAPS I DON'T KNOW HOW TO SET STATIC IP PART. I TRIED THIS..https://www.dropbox.com/s/7h7yiaa3ze4h1cf/StaticIP.jpg
    ALL NETWORK DEVICES CONNECTIONS, MODEM, USBs ARE DISCONNECTED.
    NO
  • Babylon5's avatar
    Babylon5
    A couple of points. You seem to have correctly set a static IP for the PCs wired connection, but you should go back to those settings and change the two DNS entries to the router default IP i.e. 192.168.1.1 for both entries. Disable your WiFi while trying the recovery process, it may be trying to connect to the router using the active WiFi connection.
  • Hi there, I too am having the exact same problem which occurred just after I upgraded the router software last night.
    Can you please advise if there is any course of action I can take?
    Basically the router is not recognised by the computer, so unable to run any repair ops. Not even Genie can fix.
    Please assist.
