Thudo
Jun 05, 2016Aspirant
WNDR4500v1 runs slow for all wifi-connected Android Devices within 24hrs
Firmware # V1.0.1.40_1.0.68 Wireless Security: WPA2-PSK [AES] Channel Mode: Auto Affects: all Android smartphones and tablets connected to the router's standard wifi. Laptops wifi connected or any...
- Jun 08, 2016Lovely.. guess I should figure this nearly 5 year old beast has given up the ghost and its just basically time to choose between Asus or Netgear based off sites likes smallnetbuilder.com as I want a v.powerful AC3xxx or AC5xxxx router. Wanted to wait for the next Wifi standard to replace AC but thats taking too long.
Thudo
Jun 06, 2016Aspirant
Hmm.. that's sorta not what I wanted to hear but the 4500 is ~4-5years old and we got some good mileage out of it. I wanted to wait on the next wireless standard to supersede AC but I can easily afford a new high-end router if necessary but its a toss-up between Asus and Netgear as both get exceptional reviews. Do I want the elite-end AC5300 (Nighthawk R8500 X8) or AC3200 (Nighthawk R8000 X6 which is now almost 2 years old but leads the Router charts in that AC category). As mentioned, I wanted to wait for the next Wifi standard to replace AC (which is on the way) but the situation with the Android devices is becoming absurd.
Retired_Member
Jun 06, 2016I would NOT buy another netgear product until they get their act together. I have a r8000 and don't care for it I also have a r7000 which I prefer. The last router I paid for was R6300v2 the other two were beta freebies. Elite should not be used to describe any netgear router, Guinea Pig would be more accurate.
- ThudoJun 06, 2016AspirantDo you agree with the smallnetbuilder.com router rankings then? Its a race between Netgear and Asus at the top although the lower you go in terms of AC profiles its more all over the map. I have not heard any bad things with Netgear routers the higher the AC profile goes. What specifically do you not like about those higher end models? Flaky connectivity? Limited Range? Lackluster features?
