Tech_Newbie
Oct 14, 2020Aspirant
Wndr4500v2 no internet connection
Ever since I turned my WiFi router off and on, the WiFi and internet haven’t been working. My pc prompted me to log in using admin credentials, which I did, and took me to the net gear genie page. I checked the internet status there and it said that it was good. I even tested the internet connection and it congratulated me on the internet connecting successfully. However, this did not do anything for my ability to connect to the internet on my desktop or to the WiFi on other devices. On my PC it says that there is no internet on both Ethernet and WiFi. I have tried doing a factory reset on the router, updating my PC, and unplugging and replugging the Ethernet cable that goes from the router to the motel. Anybody have any advice? I’ve got no WiFi or internet access, help!
If you have cable internet you'll have to restart the modem again also. First restart the modem and let it reboot and let it connectt to the internet. Then connect the wndr4500 to the modem and run the setup again. See if that helps out because if you have cable internet the modem marries the router so once you reboot your router you'll have to reboot the modem also first. Let us know what happens
- wcalifasProdigy
- Tech_NewbieAspirant
wcalifas There's a yellow cable connecting the motem and the wndr4500. Should I disconnect it before rebooting the motem, and when it's done rebooting, reconnect the motem and the wndr4500 via the yellow cable?
- wcalifasProdigyYes disconnect it, wait til the modem is fully booted up, then connect the wndr4500 to the modem. Make sure the cable going to the router is on the yellow internet port on the router and not on one of the 4 ports for the LAN.
