BLCain
Sep 09, 2016Aspirant
WNDR4500V3 can't schedule on/off wifi
My router is: Netgear WNDR4500V3 with firmware V1.0.0.32 I am unable to get the unit to turn off the wireless radios using the schedule under Advanced/Advanced Setup/Wireless Settings. I select "T...
ElaineM
Sep 12, 2016NETGEAR Employee Retired
Hello BLCain
Welcome to the community!
Under Advanced > Security > Schedule you may specify the correct Timezone and check for the Daylight Savings time.
Once done, verify again your settings.
- BLCainSep 13, 2016Aspirant
Thank you ElaineM.
I had at one time looked in that section but was not sure what it was for.
I set the time and tested the settings and all is working as it should.
Again, Thanks!
Now I can make sure my "little" ones are not up all night on FB.
