Zipper666
Nov 29, 2020Initiate
WNR2000.
My elderly neighbor has a Netgear N300 - WNR2000 and the power supply has failed.
It's and MT20-21120-A00F manufactured by Leader Electronics.
Online they seem to be available from various sources but using the live chat today
to see if Netgear stocks them they just keep saying "depends if it's on warranty"
when I say we don't expect a "free" one they suggest I try the website, but I
can't seem to find the correct way to ask for it.
Bottom line: DO Netgear have the power supplies described in stock and how can I
order one? If not I'll end up going on line
No. Netgear doesn't sell power supplies.
But luckily, you can get a 3rd party adapter. Just make sure it has the same voltage and AT LEAST the same amperage. You can have more but I wouldn't recommend less.
I've done this several times and its worked great.
- Zipper666Initiate
Thanks, I had come to that conclusion.
Sadly, the chat function wasn't helpful, they could simply have checked and told me that instead of
carrying on about warranty and wasting my time.
They probably could have. But sadly, netgear outsourced their support to gearhead. its made getting help challenging unless you pay for it. Which is why there's the forums.
