Wazx's avatar
Wazx
WNR2000v5 can't connect after factory reset.
I did a factory reset of my router since I needed to change some settings but couldn't remember my password. After the reset I could log in to the genie (routerlogin.net) just fine, but every time I tried the setup wizard (both automatic and manual), the wizard couldn't connect to the internet. I checked router status, and noticed that my IP address is noted as being 0.0.0.0, which might be causing the issue, but I am unable to come up with a solution for this. i haven't had this problem before in the few years I've had this router. Does anyone have any clue how to fix this?
  • michaelkenward's avatar
    michaelkenward
    What modem sits between the router and the Internet?
    After the reset, did you restart the network in the prescribed manner?
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
    How are you connecting to the router? With a browser graphical user interface (GUI)?
    • Wazx's avatar
      Wazx
      Thank you for your quick response.
      I don't know what kind of modem is used, I only have physical access to the router, not the modum.
      As for the power cycling; I forgot to mention this, but I tried it a few times before posting, but nothing changed.
      After the reset I followed the instructions in the manual to the letter, twice.
      I'm using a browser interface which I can access both through my phone's wifi and my desktop's ethernet cable.
      My router and ethernet cable seem fine, all lights are green, etc.
      Only thing that seems off is that according to the interface, my router can't get an IP address.
        michaelkenward
        So how does the Internet get to you?
        My suggestion was to reboot the whole network. Not just the router.
        That is why I asked about the modem. These are often also routers. A modem/router in front of a router can cause problems, including those you describe.
        Have you tried plugging a PC into whatever delivers you the Internet?  Leave out the router. If you can get in line, then your Internet probably comes from a router of some sort.
        If that is the case, then you could see if your WNR2000v5 will work in access point mode.
        Visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware.
        Check the section in the manual Use the Router as a Wireless Access Point
        Maybe that is how it was set up before you reset the router. That would have put it back into router mode.
        For further troubleshooting we really need to know where the Internet comes from.
