ssnickerss1
Mar 01, 2014Aspirant
20/40 mhz coexistence default value
Hello, Will someone be kind enough to give me the default value for "20/40 mhz coexistence" ? It's in the advanced tab, advanced setup, wireless settings, in the "Wireless Advanced Settings (2.4GH...
- Mar 01, 2014Should be enabled. See page 110.
Retired_Member
Mar 02, 2014If you do not select the highest mode/speed on 2.4 in makes no difference which setting you select.
