ssnickerss1
Mar 01, 2014Aspirant
20/40 mhz coexistence default value
Hello, Will someone be kind enough to give me the default value for "20/40 mhz coexistence" ? It's in the advanced tab, advanced setup, wireless settings, in the "Wireless Advanced Settings (2.4GH...
- Mar 02, 2014Should be enabled. See page 110.
Devor
Mar 02, 2014Luminary
ssnickerss wrote: Do you mean page 110 of the user manual?
Yes. Unfortunately, the user manual doesn't go into any detail, but the image shows the default value.
