obelisk1111's avatar
Oct 12, 2021
AC1200 C6230 Modem/Router Drops Internet Several TImes per Day, Have to Restart
I have now used 2 of the same modem. I returned and replaced the first one I bought to rule that out as the issue. Both modems have had the same problem. The internet works great most of the time, but at least 2-3 times per day the internet starts randomly dropping out anywhere from 20 seconds to a minute, and I eventually have to unplug and restart the modem to get it steady again. I'm getting T3 and T4 timeouts in the administration event log.
I don't want to have the Internet company come out unless I'm certain the issue is on their end, as they will charge me $100 for a tech visit if the problem is NOT on their end. Any help would be greatly appreciated.
  • plemans's avatar
    do you have a screen snip of the event log and the cable connections page? That lets us check the signal.
    Things you can do to help prevent the cable company from charging you.
    1. move the modem to right where the signal/coax enters the home.
    2. remove any splitters, amplifiers, or signal attenuators from the line.
    3. check the line for kinks, damage, old/loose/corroded/cheap/bad connections and replace them if you do.
    By moving the modem, you've ensured the lines in the home isn't causing the issue. If when you move it, the signal improves and your issues clear up, then you know its the wiring in the home and not from the isp. So get a screen snip now and when you move it to compare.
    • obelisk1111's avatar
      obelisk1111
      Guide
      Thanks for the response. I just moved into this house I'm renting at the beginning of September. There is only one cable in the house, my desk is right next to it. No splitters or anything else on the cable line, which is buried in the wall. The modem is as close to the cable as is possible. My main device is a desktop computer, and I run an ethernet cable from the modem/router directly into the computer. The only other active device is my phone, which is on the WiFi signal. When the Internet cuts out both the computer and phone drop the internet connection, so it's impacting the WiFi and ethernet the same way. This is the cable connections page and most recent event log:
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel579000000 HzLocked
      Connectivity StateOKOperational
      Boot StateOKOperational
      SecurityEnableBPI+
      IP Provisioning ModeHonor MDDIPv4 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
      1LockedQAM25617579000000 Hz7.4 dBmV40.0 dB00
      2LockedQAM2563489000000 Hz7.4 dBmV40.3 dB00
      3LockedQAM2564495000000 Hz7.5 dBmV40.2 dB00
      4LockedQAM2565507000000 Hz7.5 dBmV37.8 dB00
      5LockedQAM2566513000000 Hz7.8 dBmV40.3 dB00
      6LockedQAM2567519000000 Hz7.4 dBmV40.2 dB00
      7LockedQAM2568525000000 Hz7.6 dBmV40.3 dB00
      8LockedQAM2569531000000 Hz7.3 dBmV40.1 dB00
      9LockedQAM25610537000000 Hz7.3 dBmV40.1 dB00
      10LockedQAM25611543000000 Hz7.0 dBmV40.0 dB00
      11LockedQAM25612549000000 Hz7.1 dBmV40.0 dB00
      12LockedQAM25613555000000 Hz7.0 dBmV40.0 dB00
      13LockedQAM25614561000000 Hz7.3 dBmV40.0 dB00
      14LockedQAM25615567000000 Hz7.4 dBmV40.1 dB00
      15LockedQAM25616573000000 Hz7.1 dBmV40.0 dB00
      16LockedQAM25618585000000 Hz6.6 dBmV39.9 dB00
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA15120 Ksym/sec35600000 Hz44.0 dBmV
      2LockedATDMA25120 Ksym/sec29200000 Hz43.0 dBmV
      3LockedATDMA35120 Ksym/sec22800000 Hz42.8 dBmV
      4LockedATDMA45120 Ksym/sec16400000 Hz42.8 dBmV
      2021-10-11, 10:57:14.0Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:cf:7d:4c;CMTS-MAC=00:01:5c:6f:c2:78;CM-QOS=1.1;CM-VER=3.0;
      2021-10-10, 17:04:52.0Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:cf:7d:4c;CMTS-MAC=00:01:5c:6f:c2:78;CM-QOS=1.1;CM-VER=3.0;
      Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv6
      Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:cf:7d:4c;CMTS-MAC=00:01:5c:6f:c2:78;CM-QOS=1.0;CM-VER=3.0;
      • plemans's avatar
        Your power levels look pretty spot on.
        You can get some t3/t4 errors when its first booting/connecting and you have that.
        And you don't have any errors. If this was booted up yesterday and your not showing errors and just the bootup t3/t4, it'd keep watching it until you get the errors, then log in and get the logs/signal connections.
        Sometimes it can be an intermittent issue. I had a guy that only had issues when the wind was blowing to hard because it'd blow his coax cable (run overhead) into some trees and a hole had worn into the cable.
        but so far the signal doesn't look to bad. Who's your isp?
        Could be them pushing for docsis 3.1......
