mikejbennett80
Jul 14, 2017Follower
AC1900 Nighthawk- Ethernet Ports not working
Wifi works great but when I connect to desktop via Ethernet port 1-4 there is no connection. No lights on the AC1900 or at the port plug in.
Any suggestions? Already did a factory reset.
Thank you for your help in advance!
Mike
Hi mikejbennett80,
Try to connect a different device to the router.Use a different ethernet cable.
Sounds dead. Is this a new box?
By the way, AC1900 is not a Netgear model number, just a wifi speed indicator.
- JamesGLNETGEAR Employee Retired
Hi mikejbennett80,
Hi mikejbennett80,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
