jalambert29
Dec 29, 2021Follower
AC2000 WAC124 How do I enable smb2
I am having issues getting Map Network Drive to work on my AC2000.
the map is OK, the drive is connected to the AC2000 without any issues.
When I go to map the drive I get an error message back about running smb1 and how it isn't secure. That I should be running smb2.
Any way to enable smb2 on the AC2000
Thanks,
Jim
Netgear has set up a community forum specifically for the Business Wireless products:
https://community.netgear.com/t5/Business-Wireless/bd-p/business-wireless-for-business
Thank you. - michaelkenwardGuru - Experienced User
That's a Windows thing. Where did you see the error message?
No point in following strange advice to dive down a blackhole of a different section here.
In addition fro the, as usual, helpful advice from plemans here's another one:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
As it says here:
This reply will solve TWO Issues pertaining to Mapping a Windows Network Drive to your USB Connected Drive on your Netgear Router. This posting applies to ALL Netgear Routers utilizing Shared USB Windows/MAC File Sharing, including all current models.
