VondalSavage
Jun 10, 2021Aspirant
AC2300 - Speeds Throttled - Lemon Product?
ISP: AT&T Fiber (1GB/1GB) Make | Model: Nokia | BGW320-505 Down: 974 Mbps Up: 944 Mbps Just had AT&T out today. Updated equipment to Nokia listed above. Speeds returned to better than 80% of...
antinode
Jun 10, 2021Guru
> Feels like I was lied to about what this equipment can handle.
Might depend on how you configure it.
That includes a router, doesn't it? Cascading multiple routers can
cause multiple problems. If the router in the BGW320-505 is (still)
active, then you might want to configure the R7000P as a wireless access
point, rather than as a full-function router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a WiFi Access Point".
Or, if it's possible, disable the router in the BGW320-505, and
connect all your devices to the R7000P.
Either way, one router, not more.
