VondalSavage
Jun 10, 2021Aspirant
AC2300 - Speeds Throttled - Lemon Product?
ISP: AT&T Fiber (1GB/1GB) Make | Model: Nokia | BGW320-505 Down: 974 Mbps Up: 944 Mbps Just had AT&T out today. Updated equipment to Nokia listed above. Speeds returned to better than 80% of...
antinode
Jun 10, 2021Guru
> Feels like I was lied to about what this equipment can handle.
Might depend on how you configure it.
That includes a router, doesn't it? Cascading multiple routers can
cause multiple problems. If the router in the BGW320-505 is (still)
active, then you might want to configure the R7000P as a wireless access
point, rather than as a full-function router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a WiFi Access Point".
Or, if it's possible, disable the router in the BGW320-505, and
connect all your devices to the R7000P.
Either way, one router, not more.
VondalSavage
antinode wrote:That includes a router, doesn't it? Cascading multiple routers can
point, rather than as a full-function router.Or, if it's possible, disable the router in the BGW320-505, and
Probably should have mentioned that I have disabled the router in the BGW320-505 and that everything runs through the Netgear. Can not begin to count the number of users I've had to either configure or walkthrough configuration in order to fix the cascading router issues. Especially with fixed wireless services - big oof.
AT&T wouldn't allow me to configure their gateway to bridge mode, so I'm running it as bare bones as possible and letting the Netgear do the heavy lifting. Or at least that was my hope/plan.
- michaelkenwardJun 11, 2021Guru - Experienced User
VondalSavage wrote:Probably should have mentioned that I have disabled the router in the BGW320-505 and that everything runs through the Netgear.
What does "disabled" mean. People turning up here saying that they have turned off the wifi. But that does not disable the router bit.
VondalSavage wrote:AT&T wouldn't allow me to configure their gateway to bridge mode, so I'm running it as bare bones as possible and letting the Netgear do the heavy lifting. Or at least that was my hope/plan.
If it isn't in bridge mode, then it is likely to be still working as a router. Without knowing what you mean by "as bare bones as possible", who knows?
You are not alone in seeking help in using your modem/router
bgw320-505 bridge mode - Google Search
If you cannot find an explanation as to how to do this, then the wireless access point route is probably the easiest option. But that kills a lot of features.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
