barkhunil
Nov 11, 2017Tutor
Amber light on power lamp R8500
The same is true when pressing the RESET button.
http://www.routerlogin.net
It doesn't connect.
Please help me.
It doesn't connect.
Please help me.
Normally the power light showing amber color means there is a problem with the way the router booted, may be a firmware problem of some type but something is stopping the router from fully booting up.
- William10aMaster
Thank you.
Then, is there any way I can do it?I bought router is shop in USA in January of 2017.
Want to ask if warranty treatment is possible in Republic of Korea.The price is very high.
I can't throw this away.I like Netgear products.
Netgear products have a good quality, so I have no trouble with it.The product that I use
R8500/R7000/R6220/GS724T/GS108T/GS105E- JamesGLNETGEAR Employee Retired
Hi barkhunil,
Try this KB article to load the firmware.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
