mparsel's avatar
mparsel
Tutor
Oct 31, 2020
Android OVPN Configuration File for Firestick 4K
Is there a single OVPN cliebt configuration file for the firestick?
  • Problem solved.  all you need to do is identify the file location in the client3 file.  (e.g. ca /download/openvpn/ca.crt, cert download/openvpn/cliernty.crt, ...)
  • I would like to include the CA, Cert and Key in a single configuration file.  The firestick wont read the seperate files when running client3.ovpn.
    • mparsel's avatar
      mparsel
      Tutor
