Cannedmeat
Mar 27, 2017Aspirant
AP Mode and wired connection to TV
My router an old Apple AirPort Extreme and modem are located in my office and, I get a weak wifi signal in my living room. I'm considering buying the AC1900 and placing in the living room with both m...
- Mar 27, 2017
Yes they will still work just fine with the router set up as a access point it just allows you to connect to the main router with wired and wifi devices if wifi is enable on the second router(access point) in a remote location.
William10a
Mar 27, 2017Master
True wired connections can connect devices to to your at almost full speed of the internet you pay for and wireless has limits and walls can cut down on your range But a router as access point can bridge dead shots in a home with wifi can be a hit or miss like all wifi routers.
Cannedmeat
Thank you for your reply. So now I understand that a wired connection is better than wireless, with the AC1900 connected to my primary router using ethernet, will the LAN ports on the AC1900 still function? It seems logical to me that they would, but I don't know for sure.
Thanks
