Cannedmeat
Mar 27, 2017Aspirant
AP Mode and wired connection to TV
My router an old Apple AirPort Extreme and modem are located in my office and, I get a weak wifi signal in my living room. I'm considering buying the AC1900 and placing in the living room with both m...
- Mar 27, 2017
Yes they will still work just fine with the router set up as a access point it just allows you to connect to the main router with wired and wifi devices if wifi is enable on the second router(access point) in a remote location.
michaelkenward
Mar 28, 2017Guru - Experienced User
The easiest way to hard-wire a TV to a network is with a pair of powerline plugs.
Product FAQ: Powerline Adapters | Answer | NETGEAR Support
Powerline Networking | Powerline Ethernet | NETGEAR
