evkrieken's avatar
evkrieken
Follower
May 04, 2017
APN Nighthawk R7100LG which APN with roaming
I am using this router only in my camper with a SIM-card, so using mobile broadband. The SIM-card is from Vodafone, the SIM pin is deacticated and roaming is on. So I am travelling through Europe passing continious different networks. My first question is whether I should enter the APN from my own provider (of the SIM-card) or that of the actual delivering provider through roaming? In case of the 2nd one this would mean that I need to change this with every change of provider. Is there another solution?
  • Hi evkrieken,
    You should use the APN of the provider within the area since the Vodafone network is no longer available on the said country or area.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi evkrieken,
    • JamesGL's avatar
      JamesGL
      Hi evkrieken,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
