Brownk
Nov 03, 2022Aspirant
Assistance: R7800 TFTP macOS
Our R7800 has become unusable. Trying to upload firmware via TFTP using the following Netgear instructions:
Anybody have suggestions. Generally receive a timeout error.
Thanks.
What symptoms do you see?
TFTP is a beast to get right. Too many gotchas in there.
Have you looked any of the various videos out there?
For example:
Different hardware, same approach.
- BrownkAspirant
I have tried that video.
The first thing that would be nice to understand is whether to attach an Ethernet cable to the R7800 at the Ethernet port (yellow) or one of the WAN ports (black).
I am assuming it should be the Ethernet port (yellow)?
If I can establish which port, then maybe I can better define my results.
- BrownkAspirant
Presently, I am receiving a timeout error.
Per the attached instruction set, the power light should start flashing ambet. I does not. It naturally starts as amber at power on, goes dark, comes back amber until the activity light illuminates amber and then turns white.
