mynameisrobo
Jun 08, 2021Initiate
Avast Securty 14.9 is giving a vulnerability warning
Firmware on my R7000 is V1.0.9.88_10.2.88. When I try to upgrade, it says that I am current.
No real details from Avast on the vulnerabilty. Here is a screen capture.
> says that I am current.https://community.netgear.com/t5/x/x/m-p/2069376#M186506
> No real details from Avast [...]
Not much I can do with that.
I can't (yet) see your picture. In-line images must be approved
by a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation. In the mean time, copy+paste is your
friend.- Portwey84Virtuoso
mynameisrobo wrote:Firmware on my R7000 is V1.0.9.88_10.2.88. When I try to upgrade, it says that I am current.
You're 5 firmware updates behind the most current one:
https://kb.netgear.com/000063684/R7000-Firmware-Version-1-0-11-123-Hot-Fix
Auto router update doesn't work on this router, well it has never worked on mine AC1900 model, so just disable it.
As for firmware updates, I recommend you do a manual check at least once a month because that's the only way you'll find out if you're on the most up to date firmware.
The vague message you received is hardly an indication that Avast knows what it is talking about.
These things happen from time time to time:
Search - NETGEAR Communities – avast security
Security software is great at throwing up scary messages. They are often down to errors in its own software.
Try starting here:
Security Advisory | About Us | NETGEAR
