MRM4
Sep 14, 2021Tutor
Best signal booster for C7000
I just picked up the Nighthawk C7000 modem/router for our home to take advantage of our 400mb service. It certainly does that on a hardwired connection. The wifi connections are getting around 80mb on our laptops. While that is not slow, I was wondering what some recommended signal boosters are to go with this router to get the speed up a bit more. We live in a 1600 sq/ft house. Thanks.
Something to post about over in the WiFi Extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
A EX7700 or EX8000 will work.
Be sure to visit the cable modem forum as well:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Good Luck.
Are you testing those speeds over 2.4ghz or 5gh?
2.4ghz is a much slower network than 5ghz. It also suffers from more interference
