pmp6nl
Jun 14, 2017Aspirant
Block Device Access to Internet
I have searched, but I dont think I can find the info I am looking for. I have IP cameras on my network. I would like to prevent them from accessing the internet. How do I do that within the router? I don't want to do it on the camera side (I want to avoid the backdoor issue, etc).
Thanks
Hi pmp6nl,
You can try the block services.
Block the port number that the IP cameras uses to access Internet. (For example port 553 for HTTPs websites and 80 for HTTP).
Check under UPnP table if your camera is showing and check for the port numbers it uses.
https://kb.netgear.com/24306/How-do-I-enable-Universal-Plug-and-Play-on-my-Nighthawk-router
- JamesGLNETGEAR Employee Retired
Hi pmp6nl,
I just want to verify that you want the IP cameras to still be connected to the network but no internet access, is that correct?
- pmp6nlAspirant
Hi JamesGL,
Yes that is exactly what I want. Thank you.
Hi pmp6nl,
