jollygiant's avatar
Feb 01, 2022
Block Schedule is out of Sync with NTP Clock
When I schedule a block for 12:01 am to 6 am, the router starts blocking at 7 pm. This feature used to work. My firmware is up to date with the latest. Did a firmware update cause the problem?
The time shown in the advanced administrator section under NPT settings shows the correct, local time.
Please advise with a fix or debugging help.
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last update?
    • jollygiant's avatar
      jollygiant
      Guide
      I'm not sure. Is a factory reset recommended? Wouldn't that install an earlier firmware version?
      • FURRYe38's avatar
        jollygiant wrote:
        I'm not sure. Is a factory reset recommended? Wouldn't that install an earlier firmware version? No. Just wipes user configurations from the router.
