ncoulet73
Apr 08, 2017Aspirant
Bought a new NightHawk R7800 . Configuration portal is not accessible
Hi, I bought a Netgear NightHawk R7800. It is connected to my Xfinity Router. I have been trying to configure the router using the genie app on Phone, iPads, laptops (macs) connected on wifi or ...
- Apr 09, 2017
Thank you for sharing the Information.
unfortunately it did not work.
i managed to fix my issue by disconnecting the R7800 from my comcast router, perform a factory reset of the net gear router, and configure it without the internet from an old mac through wired network.
Then I linked it to the Comcast router again, performed a firmware upgrade and now everything seems to be working fine.
i can now use the genie app and configure the router without anymore issues.
ncoulet73
Apr 09, 2017Aspirant
