arsalann
Mar 04, 2015Novice
Bridge Mode or Access Point? What's the difference? Cascade??
Hi, Just to give you a quick background of my setup right now. I have a 4500 sqft house and currently have Uverse Internet (NVG589, 45 mbps down, 5 mbps up). I bought myself a R7000 hoping to expan...
- Mar 06, 2015Apparently you can set up the Ex6100 as an AP. This link shows how. I have never used this device, so, only can go by this doc. Scroll down to around Item 15, in the doc. Good Luck!
http://kb.netgear.com/app/answers/detail/a_id/24432/~/ex6100-initial-installation-%28access-point-and-extender%29-with-genie-smart-setup
HiSpeed
Mar 04, 2015Guide
Hi,
It is a bit delicate to use several AP because the channels must be chosen sufficiently separated to avoid interferencies.
The right choice depends on the wireless mode used, with 20 or 40 or 80MHz bandwidth.
Several AP plugged on the same network is totally different with AP wirelessly connected (client, client bridge, WDS bridge)...
