mgmihir's avatar
mgmihir
Bridge mode with 802.11ad on Nighthawk x10 R9000
Hello,
I was wondering if we can use 802.11ad on x10 to form a bridge between two x10 routers?
Thanks,
Mihir
  • Depends if the other supporting AD router supports wireless bridge mode.
  • FURRYe38's avatar
    Yes, if you are using the same R9000 as the main host router and AP and a 2nd R9000 in wireless bridge mode, it should work.
    • mgmihir's avatar
      mgmihir
      Thanks for the prompt reply.
      If I use another router supporting 802.11ad, will the bridge mode work on R9000?
      Thanks,
      Mihir
      • FURRYe38's avatar
