Fognet's avatar
Fognet
Brother HP-1440 will not USB to R7000P
 I have followed all instructions. I cannot get my HP-1440 to connect to routers USB port.
the USB light will not come on. The port works with other USB devices. And yes I have followed the manual. The problem is router will not recognize the printer.
  • plemans's avatar
    Holy cow. I was looking up manuals for that device and everything i found (brief search) was in french so it was a bit challenging to find much.
    But what I did find says that was released in 2000 and was for windows 95/98/2000.
    It still has a serial port on it.
    I'm not sure if you could get that working as for the printer utility to work, it has to have a driver installed on the pc you're using.
    Not sure if your pc has those OS's installed or if the printer utility even works on them.
    https://www.brother-usa.com/support/hl1440
    Its probably time to update the laser printer. Most decent ones have an ethernet port on them that tends to work a lot better.
    • Fognet's avatar
      Fognet
      Thanks I am using windows 11 pro. Also, unfortunately the drivers are imbedded in the printer. You are most likely right, I may have to replace it. Hate to, because the printer works great and ink lasts forever.
      • plemans's avatar
        If it still works connected to a computer, then I'd just connect it to windows and let windows share it on the network
