Gussie99's avatar
Dec 08, 2016
BT sport & extra channels not working with R7000 AC1900
Switched from BTHome Hub3 to R7000 AC1900.
Everything is working very well, except BT Sport & extra channels which are not working.
Connection set up:
wall socket > BT openreach modem > router > BT vision+ box > TV
Is there a fix for this please?
Thank you
  • Problem solved with suggestion 1 in combination with a router firmware update which now offers an additional tick box in the WAN Setup "Support BT IGMP Proxying".
    Solution
    Click on  "Advanced"->"Setup"->"WAN Setup"
    Deselect "Disable IGMP Proxying"
    Tick "Support British Telecom[BT} IGMP Proxying"
    Click "Apply"
    Thank you for pointing me in the right direction :o)
