Kingquake
Jul 06, 2021Aspirant
C3000 Ooma phone service keeps disconnecting
Ooma customer service said the disconnecting issue is the Netgear C3000 denied ports .How can I fix this?The issue seems to have happened more in last 6 months .Have done resets but still disconnects.I've had the C3000 for a couple years.
do any other devices have issues?
What actual problem are you running into?
How did they determine it was the router causing the issue?
- KingquakeAspirant
Hi plemans,Just have Ooma and a laptop connected to the C3000.No issues with laptop .Comcast is service provider.Ooma had me run a diagnostic report and it showed about 30 denied ports and I was told to contact Netgear.
some ooma's have an their own integrated dhcp server.
Have you tried putting the ooma's IP address into the netgears DMZ
