vikashummer's avatar
vikashummer
C6220 Router Modem having issues with allowing new devices to connect
When a newe user/device tries to connect to the WIFI, they get an error saying that the password is incorrect with several attempts. Very frustrating issue. Need to fix this.
  • plemans's avatar
    Is it incorrect?
    Have you went in and changed the ssid/password?
    make sure to avoid special characters/spaces.
    • vikashummer's avatar
      vikashummer
      Yes, i havent changed anything i verified on the console side. I have numbers as password, but i dont see that being an issue. i was initially able to gain access.
      • plemans's avatar
        Have you tried going in and changing it?
        then on your devices "forgetting" the network and reconnecting with the new password/ssid?
