SherryX's avatar
SherryX
Can’t find the router
I can’t find the router in my wifi list anymore after I power off/power on my AX4300. What to do?
  • plemans's avatar
    What router do you have? AX4300 is a speed.
    What modem is it connected to?
    What firmware is it running?
    What are the wifi led's on the router showing?
    Did the wifi on/off button get hit? push and hold it for 2 seconds
    • SherryX's avatar
      SherryX
      Thanks for your reply.  I reset it.  It works now.  Just so strange, the wifi disappeared suddenly.  Before I reset my rounter, I saw a very strong new wifi in other names appeared in my wifi list. But my passport didn't work. Was my wifi been hacked at that time?
      • michaelkenward's avatar
        michaelkenward
        Reset 0r restarted?
        First try to restart the router and your network.
        • Turn off and unplug modem (if there is one).
        • Turn off router and computers.
        • Plug in and turn on modem. Wait 2 minutes for it to connect.
        • Turn on the router and wait 2 minutes for it to connect.
        • Turn on computers and rest of network.
