ilian007
Dec 08, 2025Aspirant
Can I use MS80 Satellite with RS280 router ?
Hello, I wonder if I can use MS80 Satellite with my RS280 Router ? I know there is newer MS90 WiFi 7 that is compatible. However, I want to use MS80 is compatible as cheaper option. Thank ...
- Dec 08, 2025
No.
MS can only connect to there perpective model MR units:
Nighthawk MK Series MESH System Compatibility Information | NETGEAR Communities
CrimpOn
Dec 08, 2025Guru - Experienced User
I think NO.
The RS280 is a WiFi7 product. Nothing in the Product Description indicates that it can be part of a "mesh".
The MS80 is a WiFi6 product which claims to support "Easy Mesh". Alas, Netgear did not include information in the Product Description about "Network Requirments".
The MS90 is a WiFi6E product and is very clear about what it can mesh with:
