MHINO
Apr 15, 2021Tutor
can not connect with my Model EX8000
Hi, I need to go to my wifi to select de "NETGEAR_EXT" , but it just don't find it . The WPS doesn't work either .. i just don't know what to do know.
- Apr 15, 2021
the default login is:
login: admin
password: password
It usually requires you change the password during initial setup.
You can try the forgot password option. But if you didn't set it up or don't remember that either, then you'd need to factory reset it to get back to the defaults.
michaelkenward
Apr 15, 2021Guru - Experienced User
I don't uderstand that. What are you doing and where does it go wrong?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
