MHINO
Apr 15, 2021Tutor
can not connect with my Model EX8000
Hi, I need to go to my wifi to select de "NETGEAR_EXT" , but it just don't find it . The WPS doesn't work either .. i just don't know what to do know.
- Apr 15, 2021
the default login is:
login: admin
password: password
It usually requires you change the password during initial setup.
You can try the forgot password option. But if you didn't set it up or don't remember that either, then you'd need to factory reset it to get back to the defaults.
Apr 15, 2021Guru - Experienced User
Since michaelkenward has already asked it to be moved, that's taken care of.
did you already setup the EX8000? either using the installation wizard or wps?
You realize that its a mesh router? Meaning that if you set it up using wps or using the default settings, it sets up using the same ssid as the router?
- MHINOApr 15, 2021Tutorwell i finally connected with my router ! now i'm stuck with the login admin ? don't no where to find it . Sorry i'm so bad at this 🤦♂️. i already have an account , but that's not it ?
- michaelkenwardApr 15, 2021Guru - Experienced User
MHINO wrote:
well i finally connected with my router ! now i'm stuck with the login admin ? don't no where to find it .Look at the label on the EX8000.
- plemansApr 15, 2021Guru - Experienced User
login: admin
password: password
- MHINOApr 15, 2021TutorThanks alot! I'm in ! You are the best haha!
